Grafana v11.4.0 (b58701869e)
Linux Debian stable (bookworm) -
I would like to create a time series diagram with two y-axes (right and left). However, if I create a second data series on the second y-axis, I get a second separate y-axis. I would like to prevent this. I want a second unique y-axis on which I want to map different data series analogous to the first y-axis (see screenshot) -
What happened?
No
