Problems with RSS feeds' content
    Grafana v10.4.2 (22809dea50)
    Ubuntu 20.04 LTS
    I would like to get an RSS feed into a dashboard.
    I tried different approaches already.
    • News panel
    • Table panel with data source business text or infinity plugin
    • Business text panel
  • What happened?
    The RSS feed is in XML but has HTML formatting in the values.
    For example: https://infosec.exchange/tags/ixwiki.rss
    I didn’t find a solution to get rid of the html code blocks like <p> within the table panel.
    As an example:
<p>Unfounded Fears: AI Extinction-Level Threats &amp;amp; the AI Arms Race<br><a href="https://cysec.social/tags/darkreading" class="mention hashtag" rel="nofollow noopener noreferrer" target="_blank">#<span>darkreading</span></a> <a href="https://cysec.social/tags/infosec" class="mention hashtag" rel="nofollow noopener noreferrer" target="_blank">#<span>infosec</span></a> <a href="https://cysec.social/tags/cysec" class="mention hashtag" rel="nofollow noopener noreferrer" target="_blank">#<span>cysec</span></a><br><a href="https://www.darkreading.com/vulnerabilities-threats/unfounded-fears-ai-extinction-level-threats-ai-arms-race" rel="nofollow noopener noreferrer" translate="no" target="_blank"><span class="invisible">https://www.</span><span class="ellipsis">darkreading.com/vulnerabilitie</span><span class="invisible">s-threats/unfounded-fears-ai-extinction-level-threats-ai-arms-race</span></a></p>
    I was hoping there is a switch like: “render HTML in this table column” - done. :joy:
    There is not much to share I guess. Just add the URL into the data source and use the data source/panel mentioned above.
    No errors. Just the ugly HTML code in the text fields.
    OMG… you don’t want to see this browser history…
    Maybe it is better to say here: No, I didn’t try any…
Thanks @yosiasz for you fast response.
Did this work out of the box in your test? :thinking:
I’ve added a data source using this plugin pointing to the feed URL. Then I tried the business text panel using the source, but I never got the result you have.
How did you configure this? Could you maybe share it?
Got it. Let me post an example.
**{{pubDate}}**
 > {{{description}}}
&#8627; Original Toot: [<span style="color:blue">{{link}}</span>]({{link}})
looks great!
