ulrichc
December 27, 2021, 11:31am
#1
Hi there,
i have problems with alerting. My datasource is InfluxDB 1.8. I want an alert if there were less than 5 satellites found.
If i click “Preview Alerts” i get:
invalid format of evaluation results for the alert definition Grenzwert: looks like time series data, only reduced data can be alerted on.
Also i can’t use variables in the Description:
What i’m doing wrong?
wlargou
December 27, 2021, 3:46pm
#2
Indeed there are some limitations to alerting in Grafana (there is ongoing work to make them easier and better), i suggest you have a look at this threads :
The query used in an alert rule cannot contain any template variables.
hi
im new with grafana.
Grafana v6.7.3 , influxDB 1.8.0 , Telegraf v1.14.1
lately ive installed grafana to visualize my snmp metrics stored in InfluxDB server.
ive imported Dashboard and configured some panels (traffic, cpu etc graphs).
my goal is to be able to on going add more telegraf agents (sites) to my monitoring system
this is why im using a variables based dashboard, and this works just fine so when im adding a new site the devices and graph are automatically added.
my main issue…
Hope it helps.
Good Luck
