I have three grafanas deployed in docker containers and assigned to one domain in my network. I have also haproxy as a load balancer, which connecting user with choosen by its grafana instance, and I’m using keycloak for authentication.
fragment of my haproxy configuration:
# grafana http
frontend grafana
bind 0.0.0.0:<<grafana_port>>
mode http
default_backend grafana_bk
backend grafana_bk
reqrep ^([^\ :])\ <<grafana_base_uri>>/(.) \1\ /\2
balance roundrobin
# grafana checks if Host header is present if HTTP 1.1 is used
option httpchk GET /login HTTP/1.0
cookie grafana_sess prefix nocache
<<grafana_servers>>
And fragment of my grafana configuration:
[server]
# Protocol (http or https)
protocol = http
# The ip address to bind to, empty will bind to all interfaces
;http_addr =
# The http port to use
http_port = <<grafana_port>>
# The public facing domain name used to access grafana from a browser
domain = <<grafana_domain>>
# Redirect to correct domain if host header does not match domain
# Prevents DNS rebinding attacks
;enforce_domain = false
# The full public facing url
root_url = %(protocol)s://%(domain)s/<<grafana_base_uri>>
The problem is:
When I try to reach grafana with standard url http://<<grafana_domain>>/<<grafana_base_uri>>/d/<<dashboard_id>>/<<dashboard_name>>
I can reach grafana site and display my dashboard, but when I’m trying reach grafana with link with specified other organisation ID:
http://<<grafana_domain>>/<<grafana_base_uri>>/d/<<dashboard_id>>/<<dashboard_name>>?orgId=6
Connection last very long time and I’m reaching ERR_EMPTY_RESPONSE
But I can reach that other dashboard linked to other organisation, when I will click it in grafana frontend by switching organisation and choosing that dashboard.
What can I change in configuration to make grafana reachable with all possible URLs?
I’ve tried changing many parameters in haproxy and grafana and I didn’t resolve that problem.
