Problem with install loki on linux
Hi just start with grafana and want to install loki on rhel linux.
And now when i start ./loki-linux-amd64 -config.file=loki-local-config.yaml got error:
failed parsing config: loki-local-config.yaml: yaml: unmarshal errors:
line 47: field ruler not found in type main.Config
What to do in this case ?
Best regards
Mariusz
Have you checked the Loki Installation docs? Here is the link:
Hi, yes i checked instruction and make step-by-step like here https://grafana.com/docs/loki/latest/installation/local/
If this not work i will use other method…
Hello!
Did you solve your issue with error? I have the same problem
root@loki:/usr/local/bin# ./loki-linux-amd64 -config.file=loki-local-config.yaml
