I got that first error while running Loki for the first time:
C:\Users\umutc\Desktop\LokiPromtail>.\loki-windows-amd64.exe --config.file=loki-local-config.yaml
failed parsing config: loki-local-config.yaml: yaml: unmarshal errors:
line 21: field ingester_rf1 not found in type loki.ConfigWrapper
line 43: field metric_aggregation not found in type pattern.Config. Use `-config.expand-env=true` flag if you want to expand environment variables in your config file
What could I do?
Here is my .yaml file:
auth_enabled: false
server:
http_listen_port: 3100
grpc_listen_port: 9096
log_level: debug
grpc_server_max_concurrent_streams: 1000
common:
instance_addr: 127.0.0.1
path_prefix: /tmp/loki
storage:
filesystem:
chunks_directory: /tmp/loki/chunks
rules_directory: /tmp/loki/rules
replication_factor: 1
ring:
kvstore:
store: inmemory
ingester_rf1:
enabled: false
query_range:
results_cache:
cache:
embedded_cache:
enabled: true
max_size_mb: 100
schema_config:
configs:
store: tsdb
object_store: filesystem
schema: v13
index:
prefix: index_
period: 24h
pattern_ingester:
enabled: true
metric_aggregation:
enabled: true
loki_address: localhost:3100
ruler:
alertmanager_url: http://localhost:9093
frontend:
encoding: protobuf
# By default, Loki will send anonymous, but uniquely-identifiable usage and configuration
# analytics to Grafana Labs. These statistics are sent to https://stats.grafana.org/
# Statistics help us better understand how Loki is used, and they show us performance
# levels for most users. This helps us prioritize features and documentation.
# For more information on what's sent, look at
# https://github.com/grafana/loki/blob/main/pkg/analytics/stats.go
# Refer to the buildReport method to see what goes into a report.
# If you would like to disable reporting, uncomment the following lines:
#analytics:
# reporting_enabled: false
The error message is quite clear, ingester_rf1 is not a valid configuration block.
It was solved using an older version of Loki
