Friends, I’m trying to run Loki in Docker using these settings:
https://raw.githubusercontent.com/grafana/loki/v3.3.2/cmd/loki/loki-local-config.yaml
(Install Loki with Docker or Docker Compose | Grafana Loki documentation )
Here are my settings:
loki-config.yaml
auth_enabled: false
server:
http_listen_port: 3100
grpc_listen_port: 9096
# log_level: debug
grpc_server_max_concurrent_streams: 1000
common:
instance_addr: 127.0.0.1
path_prefix: /tmp/loki
storage:
filesystem:
chunks_directory: /tmp/loki/chunks
rules_directory: /tmp/loki/rules
replication_factor: 1
ring:
kvstore:
store: inmemory
query_range:
results_cache:
cache:
embedded_cache:
enabled: true
max_size_mb: 100
#limits_config:
# metric_aggregation_enabled: true
schema_config:
configs:
store: tsdb
object_store: filesystem
schema: v13
index:
prefix: index_
period: 24h
#pattern_ingester:
# enabled: true
# metric_aggregation:
# enabled: true
# loki_address: localhost:3100
ruler:
alertmanager_url: http://localhost:9093
frontend:
encoding: protobuf
And in the Loki logs, there are entries like this:
caller=scheduler_processor.go:175 component=querier org_id=fake traceID=30c8cf62a5e17c02 msg="error notifying scheduler about finished query" err=EOF addr=127.0.0.1:9096
caller=scheduler_processor.go:111 component=querier msg="error processing requests from scheduler" err="rpc error: code = Canceled desc = context canceled" addr=127.0.0.1:9096
caller=ratestore.go:109 msg="error getting ingester clients" err="empty ring"
caller=compactor.go:534 msg="failed to run compaction" err="context canceled"
If I uncomment:
limits_config:
If I uncomment:
pattern_ingester:
enabled: true
metric_aggregation:
enabled: true
failed parsing config: /etc/loki/loki-config.yaml: yaml: unmarshal errors:
line 44: field enabled not found in type aggregation.Config. Use `-config.expand-env=true` flag if you want to expand environment variables in your config file
docker compose
services:
loki:
image: grafana/loki:3.3.2
container_name: loki
restart: unless-stopped
ports:
- 3100:3100
networks:
- generic
command: -config.file=/etc/loki/loki-config.yaml
volumes:
- /home/monitoring/loki/loki-config.yaml:/etc/loki/loki-config.yaml
- /home/monitoring/loki:/data/loki
networks:
generic:
external: true
My question is: has anyone managed to run Loki without errors?
Even using the standard settings recommended by Grafana Labs, it’s impossible to run without errors. And if the configuration is more complex, does it become completely unfeasible?
I would greatly appreciate any help.
Best regards,
Alexander
Port forwarding didn’t help.
I made some changes:
I removed enabled: true in pattern_ingester, and now the container starts.
Here are my current settings with the changes:
loki-config.yaml
auth_enabled: false
server:
grpc_server_max_recv_msg_size: 20971520
grpc_server_max_send_msg_size: 20971520
common:
instance_addr: 0.0.0.0
storage:
filesystem:
ring:
kvstore:
store: inmemory
query_range:
results_cache:
cache:
embedded_cache:
enabled: true
max_size_mb: 100
limits_config:
schema_config:
configs:
store: tsdb
schema: v13
index:
prefix: index_
period: 24h
pattern_ingester:
enabled: true
metric_aggregation:
frontend:
encoding: protobuf
docker compose
services:
loki:
user: root
ports:
- 3100:3100
- 9096:9096
networks:
- generic
command: "-config.file=/etc/loki/loki-config.yaml"
volumes:
networks:
generic:
external: true
Logs *
caller=scheduler_processor.go:111 component=querier msg="error processing requests from scheduler" err="rpc error: code = Canceled desc = context canceled" addr=0.0.0.0:9096
I’m starting to lose hope.
Might I recommend you to change the gRPC port back to default 9095 and see if that fixes your problem?
If you change the default port you might have to also adjust your ring membership settings. I never changed the port, so I could be wrong.
Each time upon launch, the number of errors is different, but they are always the same.
For example, such as:
There are often many like these:
caller=scheduler_processor.go:111 component=querier msg="error processing requests from scheduler" err="rpc error: code = Canceled desc = context canceled" addr=0.0.0.0:9097
I changed the port to 9097, but nothing has changed.
compose
ports:
- 3100:3100
- 9097:9097
loki-config.yaml
server:
grpc_listen_port: 9097
logs
Maybe it’s not about the settings?
Yes, I tried, but nothing changed.
caller=scheduler_processor.go:175 component=querier org_id=fake traceID=2923e13055eb2907 msg="error notifying scheduler about finished query" err=EOF addr=0.0.0.0:9095
caller=scheduler_processor.go:111 component=querier msg="error processing requests from scheduler" err="rpc error: code = Canceled desc = context canceled" addr=0.0.0.0:9095
I even tried your Loki settings:
Unfortunately I am not able to replicate your issue, using your own configuration. Here is what I have:
docker-compose.yml:
networks:
loki:
services:
loki:
image: grafana/loki:3.1.0
command: "-config.file=/etc/loki/config.yaml -target=all"
ports:
- "3101:3101"
- 7946
- 9095
volumes:
- /root/loki/loki-config.yaml:/etc/loki/config.yaml
- /root/loki/opt:/opt/loki:rw
networks:
loki:
aliases:
- loki
grafana:
i…
I was able to get it to run without problem. Check your /ring endpoint to make sure a ring is formed.
Also, I forgot to point out, when you first start Loki empty ring is a benign error, because it’s empty until it recognizes itself as a member. If you don’t see it repeated it’s not a problem.
I have a request for you: could you run Loki with my settings on your end to check if the errors will appear or not?
Try starting and stopping the compose several times. Sometimes, the number and type of errors vary.
For example, like this one:
Here are the settings:
loki-config.yaml
auth_enabled: false
server:
grpc_listen_port: 9095
common:
storage:
filesystem:
ring:
kvstore:
store: inmemory
query_range:
results_cache:
cache:
embedded_cache:
enabled: true
max_size_mb: 100
limits_config:
schema_config:
configs:
store: tsdb
schema: v13
index:
prefix: index_
period: 24h
pattern_ingester:
enabled: true
metric_aggregation:
frontend:
encoding: protobuf
compose
services:
loki:
user: root
ports:
- 3100:3100
- 9095:9095
networks:
- generic
volumes:
networks:
generic:
external: true
If there are no errors with my settings on your end, then the issue is not with the settings. (((
