The latest version of production Grafana Oncall -
I want to install Grafana Oncall on my aws ec2 instance -
Following the tutorial: oncall/helm/oncall at dev · grafana/oncall · GitHub -
What happened?
# Install the chart
helm install \
--wait \
--set base_url=example.com \
--set grafana."grafana\.ini".server.domain=example.com \
release-oncall \
grafana/oncall
While trying to use this, I am confused with the example.com to replace in the script.
