Grafana-9.2.2
Deployed on GKE using helm chart
Oncall Plug-in-1.3.113 -
grafana oncall UI page not loading showing below error
An unknown error occurred when trying to install the plugin. Verify OnCall API URL, http://grafana-oncall-engine.grafana.svc.cluster.local:8080, is correct (NOTE: OnCall API URL is currently being taken from process.env of your UI)? Refresh your page and try again, or try removing your plugin configuration and reconfiguring. -
oncall UI page should accessible -
What happened?
image:Grafana OnCall docker image repository
repository: grafana/oncall
tag: v1.1.5
pullPolicy: IfNotPresent
image:
repository: grafana/grafanaOverrides the Grafana image tag whose default is the chart appVersion
tag: 9.2.2
