I am using grafana 11.0 and oncall plugin 1.14.0 also tested for 1.15.0 -
Trying to build grafana oncall oss production setup connecting to external grafana -
Grafana has already been used we are doing fresh installation for oncall using production helm deployment -
What happened?
There are no error logs in oncall deployement and all the pods are up and running. on call api plugin header is passed using curl as per documentation. But on IRM we could see below error related to configuration
*Grafana and Grafana oncall integration should expected to be successful -
Only error when clicked on connect icon for oncall plugin was in Grafana container “tls bad certificates”
Looking for some insights for turning on grafana on call
