Getting cetificate error on grafana instance while refreshing the OnCall page
I am currently using Grafana Version v11.5.0 and grafana-on-call v1.14.1
I am trying to setup grafana oncall on premise and I have a grafana instance running running on a different VM and oncall running on docker
Below is the docker-compose.yml file used for oncall hobby install
x-environment: &oncall-environment
  BASE_URL: $DOMAIN
  SECRET_KEY: $SECRET_KEY
  RABBITMQ_USERNAME: "username"
  RABBITMQ_PASSWORD: ********
  RABBITMQ_HOST: "rabbitmq"
  RABBITMQ_PORT: "5672"
  RABBITMQ_DEFAULT_VHOST: "/"
  MYSQL_PASSWORD: ********
  MYSQL_DB_NAME: oncall
  MYSQL_USER: ${MYSQL_USER:-username}
  MYSQL_HOST: ${MYSQL_HOST:-mysql}
  MYSQL_PORT: 3306
  REDIS_URI: redis://redis:6379/0
  DJANGO_SETTINGS_MODULE: settings.hobby
  CELERY_WORKER_QUEUE: "default,critical,long,slack,telegram,webhook,retry,celery"
  CELERY_WORKER_CONCURRENCY: "1"
  CELERY_WORKER_MAX_TASKS_PER_CHILD: "100"
  CELERY_WORKER_SHUTDOWN_INTERVAL: "65m"
  CELERY_WORKER_BEAT_ENABLED: "True"
  GRAFANA_API_URL: http://grafana-domain.org:3000
services:
  engine:
    image: grafana/oncall
    restart: always
    ports:
      - "8080:8080"
    command: sh -c "uwsgi --ini uwsgi.ini"
    environment: *oncall-environment
    depends_on:
      mysql:
        condition: service_healthy
      oncall_db_migration:
        condition: service_completed_successfully
      rabbitmq:
      redis:
        condition: service_started
  celery:
    restart: always
    command: sh -c "./celery_with_exporter.sh"
    depends_on:
      mysql:
      rabbitmq:
      redis:
    command: python manage.py migrate --noinput
    depends_on:
      mysql:
      rabbitmq:
  mysql:
    image: mysql:8.0.32
    command: >-
      --default-authentication-plugin=mysql_native_password
      --character-set-server=utf8mb4 --collation-server=utf8mb4_unicode_ci
    restart: always
    expose:
      - 3306
    volumes:
      - dbdata:/var/lib/mysql
    environment:
      MYSQL_ROOT_PASSWORD: $MYSQL_PASSWORD
      MYSQL_DATABASE: oncall_hobby
    deploy:
      resources:
        limits:
          memory: 1000m
          cpus: "0.5"
    healthcheck:
      test: "mysql -uroot -p$MYSQL_PASSWORD oncall_hobby -e 'select 1'"
      timeout: 20s
      retries: 10
  redis:
    image: redis:7.0.15
    restart: always
    expose:
      - 6379
    deploy:
      resources:
        limits:
          memory: 100m
          cpus: "0.1"
  rabbitmq:
    image: "rabbitmq:3.12.0-management"
    restart: always
    hostname: rabbitmq
    volumes:
      - rabbitmqdata:/var/lib/rabbitmq
    environment:
      RABBITMQ_DEFAULT_USER: "rabbitmq"
      RABBITMQ_DEFAULT_PASS: $RABBITMQ_PASSWORD
    deploy:
      resources:
        limits:
          memory: 1000m
          cpus: "0.5"
    healthcheck:
      test: rabbitmq-diagnostics -q ping
      interval: 30s
      timeout: 30s
      retries: 3
  mysql_to_create_grafana_db:
    image: mysql:8.0.32
    command: >-
      bash -c "mysql -h ${MYSQL_HOST:-mysql} -uroot -p${MYSQL_PASSWORD:?err}
      -e 'CREATE DATABASE IF NOT EXISTS grafana CHARACTER SET utf8mb4 COLLATE utf8mb4_unicode_ci;'"
    depends_on:
      mysql:
    profiles:
      - with_grafana
volumes:
  dbdata:
  rabbitmqdata:
configs:
  grafana.ini:
    content: |
      [feature_toggles]
      accessControlOnCall = false
the oncall setup seems to be working fine and the migration and evrything was running fine.
I am using a custom certificate on the grafana side of things. I am not sure if this is the issue is linked to the custom certificate.
below if the config from the grafana.ini file
[server]
cert_file = /etc/grafana/custom_cert.pem
cert_key = /etc/grafana/custom_cert.key
is the below error due to the oncall instance failing to make call to the grafana instance? or the other way around?
I have been working on this for weeks now, someone please help me identify the root cause.
Below are the logs of /var/log/grafana/grafana.log from the grafana VM
logger=plugin.grafana-oncall-app t=2025-02-XXT11:28:09.553170227 level=error msg="getting incident plugin settings" error="error making request: Get \"https://grafana-domain.org:3000/api/plugins/grafana-incident-app/settings\": tls: failed to verify certificate: x509: certificate signed by unknown authority, https://grafana-domain.org:3000/api/plugins/grafana-incident-app/settings"
logger=plugin.grafana-oncall-app t=2025-02-XXT11:28:09.562176745 level=error msg="getting labels plugin settings" error="error making request: Get \"https://grafana-domain.org:3000/api/plugins/grafana-labels-app/settings\": tls: failed to verify certificate: x509: certificate signed by unknown authority, https://grafana-domain.org:3000/api/plugins/grafana-labels-app/settings"
logger=plugin.grafana-oncall-app t=2025-02-XXT11:28:10.06298683 level=error msg="Error request to oncall" error="Get \"http://grafana-oncall-url:8080/api/internal/v1/health/\": context deadline exceeded (Client.Timeout exceeded while awaiting headers)"
logger=plugin.grafana-oncall-app t=2025-02-XXT11:28:10.064312739 level=error msg="Error checking OnCall API health" error="Get \"http://grafana-oncall-url:8080/api/internal/v1/health/\": context deadline exceeded (Client.Timeout exceeded while awaiting headers)"
logger=plugin.grafana-oncall-app t=2025-02-XXT11:28:10.071094503 level=error msg="Error validating oncall plugin settings" error="error making request: Get \"https://grafana-domain.org:3000/api/org\": tls: failed to verify certificate: x509: certificate signed by unknown authority"
logger=context userId=1 orgId=1 uname=admin t=2025-02-XXT11:28:10.07220013 level=error msg="Request Completed" method=GET path=/api/plugins/grafana-oncall-app/resources/plugin/status status=500 remote_addr=130.207.157.55 time_ms=535 duration=535.967447ms size=153 referer=https://grafana-domain.org:3000/a/grafana-oncall-app handler=/api/plugins/:pluginId/resources/* status_source=downstream
