I’m using the latest Grafana version provided by https://raw.githubusercontent.com/grafana/oncall/dev/docker-compose.yml -
I want to evaluate the functionality and possible use cases of Grafana OnCall -
I deployed docker-compose on my local system -
What happened?
I configured twilio credentials through ENV variables that are accepted by Grafana OnCall because I see a green check mark behind all twilio settings in the environment page.
When I try to add a phone number to a user (admin user) I get the messageCan't verify phone. Check ENV variables to configure your provider.
without any indication on what is actually wrong. I’m not able to add a phone number. -
Being able to add a phone number to the user and verify it. -
Can’t verify phone. Check ENV variables<://localhost:3000/a/grafana-oncall-app/live-settings> to configure your provider. -
Open Source | Grafana OnCall documentation
thanks for any advice
Best regards
Moritz Herrmann
