I have an issue occurs after installation,
Could not communicate with your OnCall API at http://engine:80. Validate that the URL is correct, your OnCall API is running, and that it is accessible from your Grafana instance
Please help
Please help
Hi @ahmed89,
Welcome to the
community support forums !! ![]()
Can you please tell us how you installed Grafana OnCall (i.e. which documentation you followed)?
Also, did you install OnCall cloud OR OnCall OSS?
Thanks
I am using grafana OSS and still facing the same issue i followed the documentation where we install via HELM chart .
HI @ahmed89
Where you able to solve this problem?
I have the same issue.
Hi @here
We would appreciate it if you can open a bug report about this in our official GitHub repository using this link.
Provide all the information (you can simply copy/paste your data + screenshot from here to there).
Lastly, paste the link to your GitHub issue here in this post so that all other community users can also track it. I will also add more additional information to it ![]()
Can anybody help me on how to give a connection between two tools (Sublime security and Grafana)
Error: I am able to connect sublime security to Grafana but, i am unable to reach particular user ID. it’s showing a main dashboard.
Above image explaining each user canonical ID, if i click on this ID it want to connect to particular ID but it’s not happening. I am getting main dashboard on sublime
