Docker on Debian, Grafana v10.2.2
Connect on-prem OnCall engine/plugin to grafana cloud.
All Containers are running inside my docker compose stack. I got a token from Grafana cloud for OnCall. I set the GRAFANA_CLOUD_ONCALL_API_URL env of the oncall-engine container to the URL provided in the cloud interface (eu-west in my case). In the container I can see this worked. The enviroment variable does not show in the OnCall settings in grafana.
What happened?
When entering the Token into the setting in my local Grafana I get an invalid token pop-up.
Using the provided CURL example when creating a token works fine.
The token to be accepted
See What happened
Any help would be appreciated. Thanks
Hey i had the same problem, i fixed it by adding the env to grafana itself.
As GRAFANA_CLOUD_ONCALL_API_URL=https://oncall-prod-eu-west-0.grafana.net/oncall
Hi could you explain your steps a bit more detailed? I set up my env “long” time ago and I am confused on what to do. Thanks in advance kind stranger.
So for me the problem was that I added the env to oncall-engine and not to grafana, after i added it it worked:
grafana:
image: grafana/grafana
container_name: grafana
environment:
- GRAFANA_CLOUD_ONCALL_API_URL=https://oncall-prod-eu-west-0.grafana.net/oncall
mh yeah, I am using a bare metal grafana install and a seperate oncall docker-compose. But I actually set the env variable on the grafana machine but no look sadly.
Still thanks a lot
Had the same problem, solved it like this:
- Added the URL like the others say
- Reboot entire grafana stack
- Go to /a/grafana-oncall-app/settings
- Env variables → GRAFANA_CLOUD_ONCALL_TOKEN → Click the red “reset to default” button if you see it
- Go to the “Cloud” tab, input your grafana cloud oncall api key
