With grafana install docs, i build grafana from source step by setp . At last , it works ,but after i add a datasource , the page don’t display the editor panel , like the pic. There’re no error on terminal output.
So, what’s my wrong ? How can i fix it ? Thx eveybody.
When I updated my grafana version 4.6.2 to 6.0.1 I encontred the same issue like you. See the link below.
I think It’s a browser version problem. Which version of Firefox do you use ?
I didn’t find a solution for this issue.
