I have build custom visualization panel. So now i’m searching way to define query in plugin. It’s kinda anyoying that any time I open new query I need to remove groupy by etc.
So this is default query which we all know
What i need to achieve. And yes I know you can make template variables etc. But this extension will be deployed to multiple instesnces. So I need to find a way do define query inside plugin.
I’m not really sure if this is possible because this is Vizualization plugin which has nothing to do with data source query editor.
thank you for your help.
