I’m creating my first panel plugin (I’m not a react or typescript expert) and I can’t find a way to access data from specific queries, is there a webinar or a tutorial that could help?
Here are some tips :
Hope it helps.
Good Luck
Did you also check the tutorial here :
Good Luck
Thank you very much, but I still don’t understand how to access query values and how to access specific queries, like saving queryA values in a variable and queryB values in a second one
I think that you will find examples in the following :
Good Luck
