POSTing to the /api/dashboards/db method returns ""Dashboard not found"
I have no dashboards defined, and trying to add one via the API fails, returning
{"message":"Dashboard not found","status":"not-found"}
The dashboard.id property is null (I’ve tried setting it to 0 as well)
Adding dashboards via the UI fails with the same error.
I’m running grafana 4.2.0 backed by postgres
Ok, I ended up giving up and nuking the database and starting again, it’s now all working. Not sure what happened there, but I assume the DB got into an untidy state
