Postgresql Version 9.2 issues
Hello Community,
I would like to clarify if postgrsql version 9.2 is compatible with Grafana? The dropdown only shows from 9.4 above.
Also, while adding a data source, I get an error: 504.
I do see that upon telnet port 5432, it works fine and is not blocked.
Any suggestions would be helpful.
I cannot comment on Grafana’s compatibility with old versions of Postgres, but
I hope you do realise that 9.2 came to End Of Life in September 2017.
Antony.
