Hi all, I’m using Grafana v8.0.5 (cbb2aa5001) and I need to upgrade to at least PSQL 11.x.
My current db version is 10.21
Cannot find any information about compatibility.
Can someone confirm?
Best regards,
Welcome
I would recommend you spin up/clone another grafana with v8.0.5 with PSQL 10.21
disable alerts
restore your psql db to this test environment
test if all works in test environment
Then upgrade this cloned environment’s psql to 11.x
test
(might as well upgrade grafana)
Thanks I was thinking to do that
Thanks all for the help, I can confirm the compatibility of the versions. (Created a docker compose to validate).
