PostgreSQL div/0 error on $__timeGroup fill when interval < 1s
In a timeseries panel with a PostgreSQL datasource, edit the query to this pretty simple SQL and it generates the dev/0 error.
SELECT $__timeGroup(‘2023-07-20’::TIMESTAMPTZ, ‘10ms’, NULL), 10
While this query does NOT generate the error
SELECT $__timeGroup(‘2023-07-20’::TIMESTAMPTZ, ‘1s’, NULL), 10
    9.2.1
    Not connect NULL values, but filling with NULL causes error
    With the FILL parameter of the $__timeGroup macro
  • What happened?
    Panel errors out with “runtime error: integer divide by zero”
    Query return with NULLs for missing data - this works with >1s intervals
    Query returns with error “runtime error: integer divide by zero”
We’ve tried several workarounds, like a CASE statement to not use the NULL fill param - but it turns out the $__timeGroup macro is evaluated before sending to the datasource.
So - fun test - even if your $__timeGroup query is COMMENTED OUT, it still throws the error… aka this fails
SELECT ‘2023-06-20’::TIMESTAMPTZ as “time”, 10
–SELECT $__timeGroup(‘2023-07-20’::TIMESTAMPTZ, ‘10ms’, NULL), 10
try this instead
select $__timeGroup(time, '5m', null) from (
SELECT '2023-07-20'::TIMESTAMPTZ as time
) a
Then click query inspector
And click the Query tab to see what the actual pg query looks like and post back?
@yosiasz Thanks for reading!
Set query source to your suggested
) a
Got a few errors…
  • error parsing fill value null : Changed to NULL
  • no time column found : added as time on first line
  • data is missing a number field: added back my , 10 dummy value
Ended up with this, which I think is where you were going
select $__timeGroup(time, '5m', NULL) AS TIME, 10 from (
) a
This doesn’t throw an error. Query inspection returns
select floor(extract(epoch from time)/300)*300 AS TIME from (
) a
However, when I change the interval back from 5m to 10ms I am back to the
I’m pretty sure this is a bug in the plugin that is happening before it is even sent to the database, as suggested by the error happening even on commented out code.
try that same query with the 10ms in PgAdmin, it wont work in pgadmin either. it is not a grafana issue.
select floor( ( extract(MILLISECONDS from time))/300)*300 AS TIME from (
) a
But try this in grafana instead of using the $__timeGroup function
select floor( ( extract(epoch from time) * 1000.0)/300)*300 AS TIME from (
) a
I’m pretty confident this is an error with grafana’s built in postgres datasource plugin.
Here’s a little more info: Grafana log output of a dashboard causing the error:
logger=tsdb.postgres t=2023-09-08T16:00:31.376525916Z level=error msg="executeQuery panic" error="runtime error: integer divide by zero" stack="[sql_engine.go:218 panic.go:890 panic.go:239 resample.go:93 sql_engine.go:360]"
I don’t know enough golang to debug this quickly… but I’m digging into it. It looks like a problem in the resample.go code… but the line numbers don’t line up with the grafana/grafana repo.
Did you try it in pgadmin. Unless you can prove otherwise I am sticking with my story :smile:
I’ve confirmed this is fixed in the latest version of grafana, which I built locally. V 10.2.0-pre
I haven’t found what the exact fix is… but I’m pretty sure my team is gonna wait until that version is released as a resolution to this.
