Postgres Time Series Count() issue
  • grafana-oss docker-compose
  • I have postgres as my storage, trying to create a simple time series graph. My two columns are “time” and “events”. I am trying to count each even that happened per timestamp. This is how my timestamp appears in postgres “2025-04-09T13:06:33.453”, and my events can be for example “open” “closed”.
  • This is the current sql query I have attempted
SELECT
  DATE_TRUNC('second', "time") time,
  COUNT(event) AS "open"
FROM myTable
WHERE event='open'
GROUP BY type, "time"
I am not an expert in SQL queries just a note up front.
  • What happened?
  • It seems to count them but it for some reason will have more that one same timestamp. So instead of for example all being 2025-04-09T13:06:33 - 10 , it will be 2025-04-09T13:06:33 - 2 , 2025-04-09T13:06:33 - 3 , 2025-04-09T13:06:33 - 1 , 2025-04-09T13:06:33 - 1 , 2025-04-09T13:06:33 - 3
    My goal is to combine all my events to the second to display it easier for the user. For this example, there is a lot of events per millisecond so its hard to read.
Group only by time:
GROUP BY "time"
Use this when you just want the total number of “open” events per second, regardless of any other column.
SELECT
  DATE_TRUNC('second', "time") AS time,
  COUNT(*) AS open_count
FROM myTable
WHERE event = 'open'
GROUP BY DATE_TRUNC('second', "time")
ORDER BY time;
