Hi, Im new to Grafana world.
So I’m working with a surveillance dashboard, with alot of singlestat panels. These can be colored green, yellow or red. Depending on the status of the object. When pressing on a single singlestat panel, it will redirect/drilldown to another dashboard. So here comes my question: For the top dashboard with the singlestat panels is there a way to fetch the summary of a specific(the drilldown) dashboard to base the coloring of the singlestat of a specific value in the summary?
I know at the top dashboard for each singlestat I can build a query that aggregates all the values of the panels in the drilldown dashboard. But what if all panels in the drilldown doesnt use the same datasources? I could also write a service the can fetches from all the different datasources. But I want to cointain as much as possible in grafana.
//Ben
