I am trying a Prometheus/PromQL Grafana Dashboard to InfluxDB/InfluxQL(OSS/1.8). I am facing two major problems regarding this.
- Lack of Join for different Measurements
I have the following query which in Prometheus which shows packet loss with the following query
(ifOutDiscards) * ignoring(ifDescr) group_left(ifDescr) ifDescr {job=“$Job”, instance=“$Device”}
Then I use “Out {{ifDescr}}” as a legend to get ifDescr of each ifIndex in tooltip. How to achieve this in InfluxQl. So far I am able to this
SELECT mean(“value”) FROM “ifOutDiscards” WHERE (“job” =~ /^$Job$/ AND “instance” =~ /^$Instance$/) AND $timeFilter GROUP BY time($__interval), “ifIndex” fill(linear)
- Lack of “irate” function
I have a scrape interval of 25 minutes ( I plan to reduce it to 15 seconds) so I have the following query
irate(ifOutOctets{job=“$Job”,instance=“$Device”, ifIndex=“$IfIndexAth0”}[30m])*8
I converted it to InfluxQL like this, but results are not the same
SELECT non_negative_derivative(mean(“value”), 30m) *8 FROM “ifOutOctets” WHERE (“job” =~ /^$Job$/ AND “instance” =~ /^$Instance$/ AND “ifIndex” =~ /^$IfIndexAth0$/) AND $timeFilter GROUP BY time($__interval) fill(linear)
Any help is appreciated.
