influxQL to Flux
would anyone know how would this be in Flux ?
SELECT mean(“usage_idle”) *-1 +100 FROM “cpu” WHERE (“host” =~ /^$hostname$/) AND $timeFilter GROUP BY time($__interval) fill(null)
Maybe something like this? Very difficult to get everything right without some test data.
from(bucket: "your_bucket")
  |> filter(fn: (r) => r["_measurement"] == "cpu")
  |> filter(fn: (r) => r["_field"] == "usage_idle")
  |> filter(fn: (r) => r["host"] =~ /^${host:regex}$/ )
  |> aggregateWindow(every: v.windowPeriod, fn: mean, createEmpty: false)
  |> map(fn: (r) => ({ r with newColumn: r._value * -1.0 + 100.0 }))
  |> yield(name: "your_query")
Thank you, I will try it! And confirm
Luis
