8.5 -
Trying to build a dashboard -
Get the data from the Prometheus and build the dashboard -
What happened?
With my earlier implementation with InfluxDB 1x It’s very straight forward by running the below query i can achieve it.
SELECT “App” as “Application”, “Env” as “Environment”, “Type” as “Type”, LAST(“value”) as “Total VUsers” FROM “vus_max” GROUP BY (“testid”) ORDER BY time DESC
I new to promQL and I tried different queries but not working. Don’t no how to represent it.
Need a similar output using promQL query
- Can you copy/paste the configuration(s) that you are having problems with?
(k6_vus_max{Envi!=“”, TType!=“”, RunID!=“”})
