Polystat text manipulation of variable ${__cell_name} for Clickthrough URL
Hi together,
how can i manipulate the variable ${__cell_name} for Clickthrough URL
in my case the ${__cell_name} incl. hostname & Service I want to split them into two variables for using in the Clickthrough URL
(?‘hostname’[^,]*) this is the regex for matching the hostname
the values of ${__cell_name} looks like hostname, servicename
how to handover this in the URL ???
Greets Bernd
Hello @bh2005 ,
I am facing quite a similar challenge as you, a bit different, but still some similar issues.
Have you found any solution to your problem ?
Thank you in advance,
Karafil
This seems like it should be pretty simple to port this same capability from many of your other visualization tools… how much longer before we get an answer?
