Open Links based on Values & Time Range Selected in Polystat Graph
As the title suggests - I am trying to Clickthrough these individual Hexa Polystats to Open a Stackdriver Log Explorer where based on the AppName + Time Range selected on Grafana Logs will be pulled.
9.2
Clickthrough individual Polystat Hexa to Open another Link with Dynamics Values and Selected Time Range
Has this been implemented before?
I am facing the exact challenge… Is this doable? Thanks.
sounds a little like i try to find out:
Will anyone ever respond to this?
maybe help a little,
if you using grafana Visualization Polystats and want to use dynamic value or name per cell u can try
add like this:
Name==> ${__cell_name}
Value==> ${__cell}
example:
raw
dashboard/db/cassandra?var-machine=${__cell_name}&var-result=${__cell}
result
dashboard/db/cassandra?var-machine=cassandra-sfd-0 CPU&var-result=3.24%
