plz help me with variable which should display parameter value when it crosses threshold value of 80 %
Welcome to the forum. Can you share what type of variable you have created already, and what are some examples of the type of parameter? I assume you want something more than just a word (e.g. Warning) whenever the threshold crosses 80%?
i have not created any filter … but my requirement is , Dashboard Should only display only those Fs in warning which are equal to or above 80%
It appears you are confusing some terminology. I asked if you have created any queries and you replied that you have not created any filters.
I also asked what variables you have created, but you did not reply (that was used in the title of your post).
Also, please clarify what are “Fs”?
What have you actually done so far? Are Influx and Grafana installed and working? Have you populated Influx with some same data and been able to get it to display correctly in Grafana?
Please find attached image… i am using this query to get Filesystem utilisation of selected servers… could u plz help me to modify the query ao that dashboard should only display only those Filesystem which crossed threshold of 90 %
Can you please share a sample of the results generated by your query?
please find attached sample… in this sample i am getting utilisation value of all Filesystem of selected servers… my requirement is it should only show only those Filesystem utilisation which is equal to or greater than 90 %
can someone help me on this topic
