Plus sign automatic encoding in URL
    7.5.7 on MacOS 13.2.1
    When I go to an URL with a + sign in it, I want it to stay as a + sign.
    By going to any grafana URL with a + sign in it.
  • What happened?
    The + sign is converted to %20.
    I expect the + sign to not change to %20.
    N/A, can try it anywhere on a fresh 7.5.x install. It is solved in 8.x and beyond though, and I’d like to know how.
    N/A
    N/A
In what context is this URL you are referring to? a data link?
Hello @yosiasz no particular context, just go to any Grafana install (version 7 and below) and add a + anywhere in the URL in your browser address bar and press enter. You’ll see the + sign getting converted to %20, which is not the case in version 8+.
This makes adding any links to dashboards problematic if you want to have + symbols in your variables values. Since it is effectively solved in version 8+ though, I was hoping to learn how it was solved because I want to stay on version 7 for now.
