Grafana v11.5.2 -
Migrate Grafana from VM instance to Cloud Run -
Created a persistent storage for Grafana with Google storage bucket and mounted the volume to /var/lib/grafana and host the service in Google Cloud Run -
What happened?
Plugins are not starting -
Create dashboards with the plugins -
In the UI getting - failedBackendstart error
In the logs getting following error
For every plugin I try to use, I encounter the following error in the logs:
logger=plugins.backend.start t=2025-03-10T10:39:45.110576533Z level=error
msg=“Could not start plugin backend” pluginId=grafana-googlesheets-datasource
error=“fork/exec /var/lib/grafana/plugins/grafana-googlesheets-datasource/gpx_sheets_linux_amd64: permission denied” -
Can someone pls check this
I want to add a note: When running the Docker container locally with persistent storage, the issue does not occur, and the plugins start normally. However, the issue arises only when using persistent storage in GCS on Cloud Run.
That’s because GC has different fs permissions /ownerships.
