Currently, I am trying the plugin from Flow plugin for Grafana | Grafana Labs. However, when I tried using the 3D shape in draw.io, the fillcolor function doesn’t fill the entire shape. Does fillcolor only apply to SVG with 2D shapes?
Hi @jamal
This forum is about plugin development not for plugin support.
I advice you to ask this question in the flow plugin github repository GitHub - andymchugh/andrewbmchugh-flow-panel there it might get the attention you need.
