grafana 10.4.3 (latest) -
i want to create single table panel based on pivoting (create a dynamic amount of column
I hoped for grafana transformations to cover this need but did not find a working transformation.
Desired result in one grafana table panel when a user selects 2 sensors named “sensorx” , sensor_abc
TIME sensorx VALUE sensorx TIME sensor_abc VALUE sensor_abc
30/05/2024 23:33 24740 30/05/2024 23:34 22207
30/05/2024 23:43 24740 30/05/2024 23:43 22206
30/05/2024 23:47 24738 30/05/2024 23:47 22199
31/05/2024 00:01 24738 30/05/2024 23:56 22195
31/05/2024 00:05 24736 31/05/2024 00:01 22191
31/05/2024 00:10 24735 31/05/2024 00:05 22190
31/05/2024 00:19 24736 31/05/2024 00:10 22186
31/05/2024 00:28 24737 31/05/2024 00:18 22181
31/05/2024 00:33 24733 31/05/2024 00:23 22181
31/05/2024 00:38 24731 31/05/2024 00:27 22181
31/05/2024 00:47 24731 31/05/2024 00:32 22176
31/05/2024 01:01 24734 31/05/2024 00:36 22171
31/05/2024 01:10 24729 31/05/2024 00:45 22166
31/05/2024 01:24 24724 31/05/2024 00:59 22159
31/05/2024 01:33 24724 31/05/2024 01:03 22159
source sql data (simplified) is:
time value sensor
30/05/2024 23:33 24740 sensorX
30/05/2024 23:43 24740 sensorX
30/05/2024 23:47 24738 sensorX
31/05/2024 00:01 24738 sensorX
31/05/2024 00:05 24736 sensorX
31/05/2024 00:10 24735 sensorX
31/05/2024 00:19 24736 sensorX
31/05/2024 00:28 24737 sensorX
31/05/2024 00:33 24733 sensorX
31/05/2024 00:38 24731 sensorX
30/05/2024 23:34 22207 sensor_abc
30/05/2024 23:43 22206 sensor_abc
30/05/2024 23:47 22199 sensor_abc
30/05/2024 23:56 22195 sensor_abc
31/05/2024 00:01 22191 sensor_abc
31/05/2024 00:05 22190 sensor_abc
31/05/2024 00:10 22186 sensor_abc
31/05/2024 00:18 22181 sensor_abc
31/05/2024 00:23 22181 sensor_abc
31/05/2024 00:27 22181 sensor_abc
note:
grafana repeat option in a panel shows exactly correct data, but that does not allow the user to download the desired result in one download action.
