Postgresql share query between panels, and filter different column in each
Hi I am trying to optimize my dashboards in a way that I think would be very useful, but I am not sure if that is possible in grafana. I was never strong with transformations and I find them little bit unintuitive. So I kindly ask for an advice on this topic.
    9.3.1, rocky linux 8
    Optimaze dashboard by sharing query that selects multiple columns for more panels, showing different column of the query in each panel. It gets more complicated because I use metric as well and I would like those panels that each show a column value to also make use of metric column.
    I try to use transformations to achieve it, because when using dashboard as datasource I dont see any way to interact more with data in query tab.
  • What happened?
    I have tried few transformations but none led to the goal.
    I expected to find some
    I have a simple query:
SELECT
    time_local as "time",
    command::text as metric,
    mem_perc,
    cpu_perc
FROM pid_ts
WHERE
  $__timeFilter(time_local)
ORDER BY 1,2
I would like to pick two columns in source panel as in above query (mem_perc and cpu_perc) and then use it in two other panels each showing same results as if I would issue two separate queries like this:
SELECT
    mem_perc
FROM pid_ts
WHERE
ORDER BY 1,2
SELECT
    cpu_perc
FROM pid_ts
WHERE
ORDER BY 1,2
    No
    Could not find any.
I solved that. I create first panel with query with something like:
select time_local, pid,uid,usr,sys,guest,wait,cpu_perc,cpu,minflt_per_s, majflt_per_s, vsz,rss,mem_perc,kb_rd_per_s,kb_wr_per_s,
kb_ccwr_per_s, io_delay, threads, fd_nr, command as metric FROM pid_ts
    WHERE $__timeFilter(time_local)
order by 1
then I create new panel in which I use the former dashboard panel as source and set these transformations:
Filter by name - and choose time_local, usr, metric
Partition by values - and choose metric as a field
Now all other panels that I add in this way are results of just one query :slight_smile: Let me please know if this helped someone, I wonder why no one replied or thought this was usefull in 2 months, because i think it is very useful.
No the
