Dashboard settings PostgreSQL data source
V.9.3.2
    i want to ´creat Time series queries with mutiple Graf in one pannel.
    i mean , i want to overlay several Graf in one panel by using just one code.
    on only able to achive it by chossing separently
SELECT
“Power” AS “value”,
“Zeit” AS “time”
FROM
“Haus”
WHERE
“hause_Numbe” = 1
  • What happened?
    i habe to define all 10 Hause manuelly.
i’m expectiong just on function where a chose group By Hausnumber.
so it will automaticlally know that a have 10 Hause an giving me 10 Grafs in one Panel
    PostgreSQL data source | Grafana documentation
