Pie chart from "Group by" transformation
Grafana version: 7.4.5
Datasource: InfluxDB
I need to create a pie chart with every location (metric) and the number of cars in it (value).
The query is:
select last(“locality”) as locality from locations group by “car_id”
It’s not possible to group by “locality” because it is a field, not a tag.
I’m using a “Group by” transform to group by locality with these options;
Time ->ignored
locality → group
car_id → count
and results are ok in a table panel:
locality count
New York 32
Miami 15
… etc.
but there is no way to show it as a pie chart or a bar graph.
Any ideas?. Thanks in advance.
Solved. With Grafana 8 the new bar graph does the job. A pie chart is also possible using a trick
nice! Glad G8 got you unblocked on this :+1:
would you care sharing that “trick”? Thanks.
