I am trying to get a nice dashboard for my PFsense instance, using pfSense System Dashboard dashboard for Grafana | Grafana Labs. I have tried using the ID from the dashboard and also the JSON (pasted below).
The data is in InfluxDB, no errors tthere, and I am not getting any errors in PFsense.
This is the error I am getting in the grafana dashboard
invalid: compilation failed: error at @1:32-1:54: expected comma in property list, got REGEXEQ error at @1:39-1:53: string literal key host must have a value error at @1:46-1:53: unexpected token for property key: REGEXEQ (=~) error at @1:59-1:60: invalid statement: $
For PFSense, using the Telegraf plugin, I have pasted the below into the Additional Configuration for Telegraf section:
[[outputs.influxdb_v2]]
urls = ["my internal ip:8086"
token = "my token from InfluxDB"
organization = "Porkchop, LLC"
bucket = "pfsense"
For the JSON - do I need to change Versions for Influx and Grafana at the top? I tried it but reverted since it didnt fix the issue. What about the inputs? I have changed those but still an issue.
JSON (truncated because of space limits on forum posts, but entire JSON can be found here: pfSense-Dashboard/pfSense-Grafana-Dashboard.json at master · VictorRobellini/pfSense-Dashboard · GitHub
“__inputs”: [
"name": "pfSense", <***< what should this be? Name of what?***
"label": "pfSense", *<< what should this be? Label of what?*
"description": "",
"type": "datasource",
"pluginId": "influxdb", ***<< Same here, not sure if this should always be InfluxDB or?***
"pluginName": "InfluxDB" ***<< Same, not sure of the values that are supposed to be here***
“__requires”: [
"type": "panel",
"id": "gauge",
"name": "Gauge",
"version": ""
"type": "grafana",
"id": "grafana",
"name": "Grafana",
"version": "7.4.3" ***<< should I change this to my version of Grafana? Would this wrong version break the dashboard?***
"type": "panel",
"id": "grafana-worldmap-panel",
"name": "Worldmap Panel",
"version": "0.3.2" ***<< Not sure what version of Worldmap Panel I have, but if I can find that out should I change this?***
"type": "panel",
"id": "graph",
"name": "Graph",
"version": ""
"id": "influxdb",
"name": "InfluxDB",
"version": "1.0.0" ***<< Should I change this to my InfluxDB instances version?***
