Grafana v8.3.2 (standalone client)
debian + nginx -
Setup Synthetic Monitoring plugin -
- I register cloud account and generated api keys;
- Installed plugin on my local grafana;
- Created configuration and tried to initialise it throw Web-UI;
- What happened?
- I pressed on Enable plugin button with admin api key entered;
- After loading pictures and enabling plugin i pressed Initialize the plugin
Then request /api/plugin-proxy/grafana-synthetic-monitoring-app/install happened with publisherToken
- status 200 and i got accessToken in response with all correct data from configuration
Then after several requests grafana execute /api/datasources with accessToken inside
- status 403 Permission denied
Successful initialisation of Synthetic Monitoring plugin -
I tried:
- All api keys (admin/viewer/editor etc) into parameter basicAuthPassword - always Permission denied
- All api keys (admin/viewer/editor etc) into parameter publisherToken - only Metric Publisher is ok, with others got error: {“msg”:“provided token does not have MetricsPublisher role”}
- Regenerated all api keys including admin api key used in “What happened? step #1” - always Permission denied
Can anyone advise what my next steps are?
