Hi All,
Just wondering if there is a way that you can use the percentile function on a fixed time range instead of $__range_series.
Basically i want a panel that always shows the 95th for the current month and one that shows for fast month i thought you might be able to do something like this
but it doesn’t seems to work.
Thank you in advance
