Percent % display
Hello everybody regarding the screenshot i want to display percent % near to 88 to be 88% “it is a calculated value”
You can select the unit as : percentage to make it work.
i tried it ,thinks but it dsplay % on all value for i want just to apply percent on 88
it is level of supply for a printer
Oh, in that case, you can do field override.
Thanks you are genius
