Hi
I have a Kubernetes environment and using Grafana to visualise metrics streamed from Prometheus.
I have application counters which are not fed to Prometheus. However I am able to view them as a JSON object by using a curl command.
http://10.0.0.1:8081/api/events/
Response has the following format:
"ID": "001",
"source": "pageloads",
"summary": "high failure counts",
"severity": "major"
"ID": "003",
"source": "profile_counts",
"summary": "profile count doesn't match number of groups",
"severity": "minor"
"ID": "002",
"source": "number of subscribers",
"summary": "profiles higher than subscribers",
"severity": "critical"
Is there a plugin to query this data (http://10.0.0.1:8081/api/events/) in Grafana?
Thank you
