Grafana v11.0.0
OS windows 10 -
Parse query using jsonata -
See json and parsing below -
What happened?
Getting error:
error getting data frame from inline data. root object doesn’t exist in the response. -
see details below -
I used JSONata Exerciser from web: https://try.jsonata.org/
to parse the json. This works well and the outcome can be visualized by grafana.
However, when uploading the data, and using jsonata parsing (same code), I get an error
Error on grafana
parsing in JSONata Exerciser
Visualization by using the JSONata Exerciser as grafana data
error getting data frame from inline data. root object doesn’t exist in the response. Root selector: ( $a:=People{$string(rank):data} ~> $each(function($r, $d){ $r{time: hight} ~> $each(function($v, $k) { { “rank”:$d.$number(), “time”: $k.$number(), “dataPoint”: $average($v.$number()) } } ) }); $a.*; ) -
No
