Parse multiple JSON values
I am using last community version in March, 2025 and I am trying to parse all the values in the arrays data in the answer below from Inflinity plug in.
  "/Random/Int1": {
    "request": {
      "tag": "/Random/Int1",
      "start": 1740927000000,
      "end": 1740927060000,
      "options": {
        "remoteNode": null,
        "mode": "raw",
        "method": null,
        "interval": null,
        "deadband": null,
        "invalidAsNull": true,
        "limit": null
    "data": [
        1740927000000,
        119,
        192,
        2
        1740927002986,
        37,
        192
        1740927008002,
        57,
        192
        1740927013020,
        23,
        192
        1740927018034,
        71,
        192
        1740927023046,
        92,
        192
        1740927028064,
        70,
        192
        1740927033075,
        17,
        192
        1740927038091,
        43,
        192
        1740927043107,
        41,
        192
        1740927048121,
        121,
        192
        1740927053141,
        95,
        192
        1740927058155,
        51,
        192
  "/Random/Int2": {
    "request": {
      "tag": "/Random/Int2",
      "options": {
        "remoteNode": null,
        "mode": "raw",
        "method": null,
        "interval": null,
        "deadband": null,
        "limit": null
    "data": [
        1740927000000,
        26580,
        192,
        2
        1740927002986,
        7897,
        192
        1740927008002,
        14397,
        192
        1740927013020,
        25887,
        192
        1740927018034,
        22599,
        192
        1740927023046,
        24694,
        192
        1740927028064,
        3756,
        192
        1740927033075,
        1798,
        192
        1740927038091,
        9426,
        192
        1740927043107,
        13132,
        192
        1740927048121,
        18918,
        192
        1740927053141,
        18332,
        192
        1740927058155,
        31692,
        192
  "/Random/Int4": {
    "request": {
      "tag": "/Random/Int4",
      "options": {
        "remoteNode": null,
        "mode": "raw",
        "method": null,
        "interval": null,
        "deadband": null,
        "limit": null
    "data": [
        1740927000000,
        24588,
        192,
        2
        1740927002986,
        10502,
        192
        1740927008002,
        16735,
        192
        1740927013020,
        10336,
        192
        1740927018034,
        10962,
        192
        1740927023046,
        20753,
        192
        1740927028064,
        89,
        192
        1740927033075,
        29761,
        192
        1740927038091,
        10768,
        192
        1740927043107,
        28726,
        192
        1740927048121,
        27041,
        192
        1740927053141,
        25417,
        192
        1740927058155,
        14269,
        192
I am able to read individual values directly using for example "/Random/Int1.data.[0][0]’ as a column to parse a timestamp. However, I need all the values in the arrays “data” per tag to build time series trends. I tried to use different resources (JSONata, Columns, UQL), including suggestions from Grot AI, chatGPT, Gemini and Deepseek without success.
Thank you for your help!
Welcome @engacosta
Please repost that JSON as a properly fornatted json
Hi yosiasz. Thank you for the quick reply.
I edited the original message with the formatted JSON.
here is a lead, play around with it so that you can use jsonata to get what you need
https://try.jsonata.org/IWsGP3E_S
