Parallel Test is giving error
I am trying to run following parallel test. But I get folllowing error.
import “./libs/shim/core.js”;
import “./libs/shim/urijs.js”;
import http from “k6/http”;
import { sleep } from ‘k6’;
export {default as script1} from ‘./test1.js’;
export {default as script2} from ‘./test2.js’;
export let options = {
scenarios: {
    'scenario1': {
        executor: 'per-vu-iterations',
        vus: 10,
        iterations: 10,
        duration: '10s',
        exec: 'script1',
    'scenario2': {
        vus: 3,
        iterations: 3,
        duration: '15s',
        exec: 'script2',
I am getting the following error when I execute this.
ERRO[0004] json: unknown field “duration”
ERROR: 255
What am I missing? Is it because script1.js and script2.js have their own separate options and thresholds? I want the ability to run the tests separately as well as in parallel. Is it possible?
Hey @Jay
Welcome to the community :partying_face:
If you want to use executor (per-vu-iterations etc.), you need to use the maxDuration instead of duration. You can review the document below.
Thank you.That worked.
