I want to execute multiple k6 test scripts in parallel. They are in separate files with their separate thresholds. I am developing custom thresholds for each API to monitor their duration, waiting, and blocked time. Now some of the API’s are common in all the tests scripts files.
// Test file 1
import { check, group } from 'k6';
import "./libs/shim/core.js";
import "./libs/shim/urijs.js";
import http from "k6/http";
import { Rate, Trend, Counter } from 'k6/measureMetrics';
import { sleep } from 'k6';
import {measureMetric} from "./measureMetric.js";
//const iWaitTime = 3000;
let API1 = new measureMetric("API1");
let API2 = new measureMetric("API2");
let API3 = new measureMetric("API3");
export let options = {
thresholds: {
http_req_failed: ['rate<0.01'], // 99% availability
http_req_waiting: ['p(95)<3000'], // 99% latency
API1_Duration: ['p(95)<3000'],
API1_Blocked: ['p(95)<3000'],
API1_Waiting: ['p(95)<3000'],
'checks{scenario1:scene1}': ['rate0.9'], //90% checks success
API2_Duration: ['p(95)<3000'],
API2_Blocked: ['p(95)<3000'],
API2_Waiting: ['p(95)<3000'],
'checks{scenario1:scene2}': ['rate0.9'], //rate of successful checks should be higher than 90% for
'group_duration{group:::grpAPI}' : ['avg < 5000'],
'checks{scenario1:files}': ['rate0.9'],
checks: ['rate0.9'], //rate of successful checks should be higher than 90%
'checks{scenario1:scene3}': ['rate0.9'],
API3_Duration: ['p(95)<3000'],
API3_Blocked: ['p(95)<3000'],
API3_Waiting: ['p(95)<3000'],
const url = "https://abcd.com";
const params = {
headers: {
'Authorization':'abcs',
'Content-Type': 'application/json'
export default function() {
let accountNo;
//1.api 1
let name = { 'Act1' };
let endPoint = "/abcd/";
let res = http.post(url+endPoint, JSON.stringify(name), params);
check(res, {
'is status 201': (r) = r.status === 201,
{scenario1 : 'scene1'},
API1.trackDuration(res);
API1.trackBlocked(res);
API1.trackWait(res);
accountNo = res.json().accountNo;
console.log(res.body);
//2.API 2
data = {"abcd"};
endPoint = "abcder";
res = http.put(url+endPoint, JSON.stringify(data), params);
check(res, {
{scenario1 : 'scene2'},
API2.trackDuration(res);
API2.trackBlocked(res);
API2.trackWait(res);
sleep(5);
//13. API 3
data = {"abcd"};
endPoint = "ghggh";
res = http.put(url+endPoint,JSON.stringify(data), params);
console.log("edit account");
check(res, {
{scenario1 : 'scene3'},
API3.trackDuration(res);
API3.trackBlocked(res);
API3.trackWait(res);
//Test 2 file
import { Rate, Trend, Counter } from 'k6/metrics';
let API4 = new measureMetric("API4");
thresholds: {
API1_Duration: ['p(95)<5000'],
API1_Blocked: ['p(95)<5000'],
API1_Waiting: ['p(95)<5000'],
API2_Duration: ['p(95)<1000'],
API2_Blocked: ['p(95)<1000'],
API2_Waiting: ['p(95)<1000'],
'checks{scenario1:xx}': ['rate0.9'],
API4_Duration: ['p(95)<3000'],
API4_Blocked: ['p(95)<3000'],
API4_Waiting: ['p(95)<3000'],
const params = {
headers: {
let accountNo;
//1.api 1
check(res, {
//2.API 2
data = {"abcd"};
check(res, {
sleep(5);
//13. API 3
data = {"abcd"};
endPoint = "ghggh";
check(res, {
{scenario1 : 'scene4'},
API4.trackDuration(res);
API4.trackBlocked(res);
API4.trackWait(res);
How do I run them in parallel ? I want to track each common api (like which test/scenario ran it. It will help me to develop dashboards) . How do I do that? I developed following parallel test but its not sufficient. When I run it it gives me the breakup of API 1 but not the others. So I don’t know what is happening?
Can anyone help?
import "./Test1.js";
import "./Test2.js";
export {default as script1} from './Test1.js';
export {default as script2} from './Test2.js';
export {options as options1} from './Test1.js';
export {options as options2} from './Test2.js';
scenarios: {
'scenario1': {
executor: 'constant-vus',
vus: 10,
duration: '1m',
exec: 'script1',
'scenario2': {
executor: 'per-vu-iterations',
vus: 10,
iterations: 20,
maxDuration: '10m',
exec: 'script2',
