Panel plugin using setting from Datasource plugin
I have 1 Datasource plugin and 1 Panel plugin.
I want to use the settings: URL, username, password that I have set at Datasource plugin to use in Panel plugin.
In the Panel plugin I will use the URL (API), username, password to get the data using axios.
Can someone help me or have related documents will share it for me
Thanks.
