What Grafana version and what operating system are you using?–>13.0.1 ; Windows
What are you trying to achieve?–>Trying to build an overview dashboard in tabular format that can show diff rates from diff panels of different dashboards. The process is using prometheous as data source
How are you trying to achieve it?–> In the grafana dashboard try to build the tables with headers and status and percenatge of error (fetched from diff panel) but that data is not coming up
What happened?
What did you expect to happen?–>Real time % data should be fetched from diff panel and shown in overview
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.–>No
Did you follow any online instructions? If so, what is the URL?–>No
Welcome @ibanerjee28011999 to the community
Grafana’s built-in “Dashboard” data source can only reference panels within the same dashboard → not across different dashboards. So to build an overview table pulling metrics from multiple dashboards, you must re-query Prometheus directly in your overview dashboard.
Find your exact metric names
Open any existing source panel → click Edit → copy the PromQL query shown. That is your base query for the overview.
Alternatively go to your Prometheus URL → Query tab → start typing your metric name → autocomplete shows all available metrics.
Create overview dashboard
Dashboards → New Dashboard → Add visualization → select Prometheus as data source → change visualization to Table (top right)
Add queries
Add one query per metric. For each query set:
- Format = Table
- Type = Instant
If you want one row per service add by (service) to your PromQL:
promql
sum by (service) (rate(your_error_metric[5m]))
Transform tab
Add → Merge series/tables
Then add → Organize fields by name:
- Rename
Value #A→Error % - Rename
Value #B→Latency - Rename
Value #C→Uptime % - Hide
Timecolumn
Field overrides
Add field override for each column:
- Thresholds: 0 = green, 2 = yellow, 5 = red
- Cell display mode →
Color background
If you share your existing panel’s PromQL query I can write the exact query for your overview table
