Hello
Is it possible integrate OTRS and Grafana?
The OTRS’s dashboard are very poor…
Thanks.
Ivan
Hello
Thanks.
Ivan
The Zabbix App (code on GitHub) would be similar if you want to start developing an app for OTRS.
Is there an API that give you access to the data?
Well, i dont kwon if OTRS has a open API, but i try to acess OTRS database using a SQLDB plugin. Access directly mysql database and do querys.
But SQLDB is not working fine with the lastest Grafana’s version.
When grafana will have a plugin for others databases (link mssql, postgresql or mariadb/mysql) will be able to do dashboards for the most of systems.
These is possible on the next grafana’s roadmap?
Here is the Grafana Roadmap.
A MySQL data source is in development and is already available in nightly builds and will be released in v4.3.0 in the next few days.
It is a wonderfull News!!!
I installed grafana-4.3.0-7748pre1 to test mysql datasource.
when a try a query, i get these error:
dial tcp: address (my mysql ip address): missing port in address
I Try configure host:port, but i got the same error.
This is what the connection details should look like. No http:// before the hostname. That error you are getting means the connection string is wrong.
Thanks. Its working mysql connection
Now i have some issues in select time…
For example, In the mysql select command:
SELECT DATE(ticket.create_time) AS 'Date', COUNT(ticket.id) AS '# of tickets'
FROM ticket
INNER JOIN
queue ON ticket.queue_id = queue.id
WHERE
ticket.queue_id IN ( SELECT id FROM queue WHERE valid_id=1 ORDER BY name)
GROUP BY DATE(ticket.create_time);
Results:
| Date | # of tickets |
| 2016-12-14 | 1 |
| 2016-12-21 | 1 |
| 2017-03-09 | 1 |
| 2017-03-22 | 1 |
| 2017-03-28 | 1 |
| 2017-03-29 | 1 |
| 2017-03-31 | 3 |
| 2017-04-03 | 1 |
| 2017-04-04 | 1 |
| 2017-04-06 | 1 |
| 2017-04-24 | 1 |
| 2017-04-25 | 7 |
| 2017-04-26 | 5 |
| 2017-04-27 | 1 |
| 2017-05-04 | 2 |
I need Date and tickets became X and Y axes in grafana, but i cant do, uning time series.
Anyone can help me?
Old entrie but I had the same problem:
You have tu change the output format of ticket.create_time and column names are pre definated by grafana:
SELECT UNIX_Timestamp(ticket.create_time) AS time_sec, COUNT(ticket.id) AS value
FROM ticket INNER JOIN queue
WHERE ticket.queue_id IN ( SELECT id FROM queue WHERE valid_id=1 ORDER BY name)
For reference I made dashboards to view the results in the OTRS Survey module.
Hi, Marcelo!
I saw your dashboard and it was much of help for me.
Maybe you could help me with a graph panel? I tried to use yours as a base, but I failed at this task.
I want to make a graph panel showing the opened and closed ticket in a interval of 3 months. Something similar to this:
Do you know how can I achieve this?
