Connect Grafana with TERADATA or Via ODBC
Hi everyone, do you know if there is a plug in or some kind of way to connect grafana with a TERADATA databse, or using ODBC?
Thanks in advance
There is no direct support for JDBC or ODBC currently. You could get this data in time series form and into Grafana if you are prepared to do some programming.
Reference :
Good Luck
There is an ODBC based plugin now: Sqlyze Datasource plugin for Grafana | Grafana Labs
or you can write your own rest api or graphql endpoint like @wlargou
