How to connect Grafana to Impala
Hi Team,
I’ve been searching for a plugin or something that can help me to connect my Impala data source to Grafana but no luck.
Can you please help me that how can I connect my Impala data source to Grafana via JDBC connection.
Thanks & Regards,
Ayush
Welcome @ayushbajpaibitmesra
Did you see/try this plugin? They mentioned Impala.
Hi @grant2 ,
Can you please confirm whether the plugin which you’ve shared is only available for enterprise edition or not because in one of the posts I’ve read that it works only with Enterprise edition ?
Thanks & Regards,
Ayush
I cannot confirm that, as I have no experience with that plugin. I suggest you contact the plugin author or inquire about Grafana Enterprise if this datasource is critical.
Hi @grant2 ,
Thank you so much for the confirmation. Well actually got the answer, under installation it’s mentioned that work with Grafana Enterprise edition.
Thanks & Regards,
Ayush
